Displays Flow Monitor key information.
| key | Specifies the Flow Monitor key. |
| key_name | Specifies the assigned name of the Flow Monitor key. Range is 32 characters. |
| all | Specifies to show Flow Monitor information for all keys. |
| detail | Specifies to show all information associated with the specified key. |
N/A.
For each key, the name, type, associated group name (if applicable), and the 'before' or after key name (if applicable) are displayed.
When all is entered and detail is not specified, all keys are shown in tabular format.
When detail is entered, the IPv4 or IPv6 address and mask, source or destination UDP or TCP port, protocol or next header, and specified list of ports to which the key is applied are shown. If none are specified, all values are shown.
The following command displays information for a key with the name 'src-ipv4-addr':
# show flowmon key src-ipv4-addr
This command was first available in ExtremeXOS 32.2.
This command is available on ExtremeSwitching 5420, 5520, and 5720 series switches.
